SD-WAN | INTERNET OVER MPLS
fsantos
Hi Community!
  I need your opinion about the following topology, I currently have an MX with an internet link and an MPLS link, I would like to know if you have found a way to conmute the internet over MPLS, that is, when the local internet goes down use the internet over MPLS, maybe with a default route for example . I have placed an image as a reference of the topology, at the moment according to the documentation that I have found it is not possible, but perhaps you have found a solution
StevePF
Same here, I used this configuration as a transition from MPLS to Internet-based SD-WAN.
But I add some additional stuff, like allowing split tunnel and use WAN 1 (Internet circuit) as Primary uplink and disabled the load balancing.  I also added some SD-WAN policies to use WAN 2 (MPLS circuit) for voice and some sensitive traffic to our DC.
This was more predictable until I all the MPLS circuits were removed. After that, I used the uplink load balancing and modify the SD-WAN policies to use the best for voice or other custom performance classes.
10 Replies 10
fsantos
Thanks for you answer, currently i have this solution in my infraestructure.
MPLS Failover to Meraki Auto VPN - Cisco Meraki
We have a similar requirement and at the hub we have the MXs in single ended concentrator mode.  That allows it all to work as you wish.
StevePF
fsantos
Thanks!
rpidcock1
So in this scenario, did you peer any routing protocols with the MPLS provider?  Did you enable BGP on your MX?
fsantos
At that time there was no BGP feature, I did it with conditional static routes. Now the bgp option makes more sense.
rpidcock1
So are you using BGP today, or still static routing.
fsantos
still static, but I am considering BGP.
rpidcock1
I'm actively working on trying to get a site setup with this very scenario.  My problem is that I have different ASN's at my remote branches (i.e. 646xx where xx = branch number).  I'd love to visit with you sometime if you had a few minutes to chat about the overall setup.  Maybe we could compare notes a little as to our specific network environments.
Send me a direct message if you'd like to try to link up for a brief discussion.
