Retransmissions (Port 179, BGP, IPv6) on Site-to-Site capture when using warm spare configuration
ksumann
Hello everyone,
can somebody confirm this?
If i do a packet capture on interface "Site-to-Site VPN" on a spoke, i have a lot of TCP retransmissions with packets using IPv6 and Port 179 (BGP) when the concentrator is configured in warm spare mode.
Those retransmissions doesn't exist when the concentrator is stand alone.
vs
9 Replies 9
RaphaelL
I don't know what MX version you are running but I was seeing the same behavior on MX 18.107.6
I couldn't care less about ipv6 so I didn't bother opening a case.
ksumann
I'm using 18.107.2 and i want to save the extra traffic those retransmission causes.
Do you currently use another version and the issue is gone?
RaphaelL
Went to a different architecture with HA/Warm spare. Like mentionned by ww , don't think this is supported yet in any version.
I supose that is incoming traffic?
Because warm spares dont support ipv6 so they dont reply to any ipv6 traffic
RaphaelL
Yes that seems to be the case ! Good point
ksumann
But isn't that the BGP traffic by the MX /AutoVPN itself? How does BGP even work then? In the same capture there are no IPv4 BGP packets.
RaphaelL
Do you have eBGP configured on your Hub ? if so , BGPv4 must be running
ksumann
SDWAN -> Routing -> BGP is not enabled. Because of the firmware version / MX Hardware i'm not even able to enable it.
ksumann
Does anyone know if this is fixed in a newer version?
Or is it safe so "disable" those packets with a firewall rule? Or is there another option to disable it?
