Thanks for the reply.
by Idp do you mean identity provider? I have configured Azure SAML for admin login and that seems to work fine:
I can log in to the admin dashboard via Azure.
I have also configured SAML settings in deployment:
and when I "test" that configuration it says it passes.
However, I can't find or see anything that identifies whether or not if a user authenticates via AnyConnect Azure SAML whether or not they will be authenticated to Umbrella and thus can have policies etc. applied to their Azure account.
Does this Idp allow this? Is there somewhere I'm missing where this would get configured?
Appreciate the help.
