Restrict traffic on the failover WAN
trunolimit
Hello Community,
I've got an MX67. WAN2 is set up as a fail over WAN but my issue is that it's actually an LTE router. I do not want all traffic to flow over that WAN when WAN1 dies. I only want mission critical traffic to run over that WAN.
How can I accomplish this. All mission critical stuff are on their own VLAN so restricting traffic via VLANs or Subnets is OK by me.
Thanks for the help.
Bruce
Give support a call, they should be able to configure your network so that the Cellular firewall rules apply to WAN2 for exactly this purpose - allowing you to restrict what goes out WAN2 further.
5 Replies 5
Bruce
trunolimit
Oh, Is it one of those back end things that only support can do like monitor hardware resource usage and temp?
Bruce
Yep, its one of them...
trunolimit
I wonder what the reasoning is for that. Like why not give us insight into CPU utilization and stuff like that.
GreenMan
Meraki Employee All-Star
Giving access to lots of information actually often makes customers' working lives much more complex.   If you have an issue, your license allows you to contact Meraki Support - let them worry about the complexity of (for example) When does CPU utilisation become excessive?   Meraki is pretty obsessive about making technology as simple as possible.
(BTW - if you haven't found it before, Meraki makes available an overall MX appliance utilisation number, under Organization > Summary report)
