Port Forwarding
firefly165
Just browsing
Port Forwarding
I have a question about port forwarding.
I need to have multiple ports forwarded to 2 different IP addresses within the network.
tcp/1935
tcp/3478
tcp/3480
udp/3074
udp/3478
udp/3479
These ports need to be forwarded to both 10.0.0.52 and 10.0.0.92.
It is no problem to set these ports up for either one of these addresses, But when i want to add the same port numbers to the second ip address i get an error stating i cant enter the same port number twice.
How can i make it possible to allow access to both these addresses.
Thanks in advance
AnythingHosted
This is not going to be possible, assuming you have only 1 external IP address. How will the router know to forward to .52 and not .92 and vice versa.
If you have two external IP addresses, one could forward to .52 and the other to .92.
LasseBang
Hi.
When doing port forward you can only forward to 1 internal ip... On any given port..
If you want to do this you need more public ip and then use 1:1 NAT
AnythingHosted
mikefour
good questions
