Recommended USB SIM Cellular Devices
YBerllan
Hi All,
We are having issues find the right USB SIM Cellular device to work with the SD-WAN Units. Does anyone have a recommend list of devices that work with the MX devices.
Kind regards
2 Replies 2
Uberseehandel
I've looked at that list.
I would suggest asking your preferred MNOs which USB modem devices they currently supply.
Many of us are not able to use Huawei LTE devices.
If you have 5G coverage, it is worth going for it. Some appliances may be able to handle 5G speeds through the USB port.
