Public IP showing diffrent MX 64
Shubh3738
Could you please help me, public ip showing different in configurations.
KarstenI
Some ISPs NAT the customer's public IP to a different public IP. This could be the case here.
Is the ISP modem connected directly to the MX? Is your IP dedicated?
Otherwise open a support case.
DarrenOC
Hi @Shubh3738 , appreciate that you’ve masked your actual IP address but not masked the Gateway IP.  Considering you’re probably on a /29 it wouldn’t be difficult to guess the actual IP.  Might want to mask the lot.
KarstenI
