Port 25 between Vlans and sd-wan not open
SeaTec
Short description of our layout.
Two sites
two mx84's
redundant internet connection on both sites
several vlans on both sites with different subnets
We have a ipo server on site 1 in vlan1010 that needs to port 25 to a secondary ipo server on site 2 on vlan1020
We can telnet test to port 2525 and the server answers.  when we try to telnet to port 25  no answer
I've been combing through the mx settings but cant see where that port would have been blocked.
Any suggestions?
It can be blocked at the vpn firewall.  Or by ips/amp (security center)
If not, did you take a packet capture at the destination mx or server to see if the packet is going from the dst mx to the dst server at port 25?
If you see the packet going to the server , and nothing comes back, the server is probably not allowing it
Stealth_Network
I assumed you checked the firewall rules but also check the content filtering, VPN rules, and traffic shaping. (Content has caught me on a few unusual connections)
GreenMan
Have you built VPN between the sites or are you exposing the server(s) via port forwarding / NAT?   https://documentation.meraki.com/MX/NAT_and_Port_Forwarding/Port_Forwarding_and_NAT_Rules_on_the_MX
SeaTec
My apologies. A contractor swore the issues wasn't on the IPO servers when under closer inspections it was a misconfiguration of the service.  Sorry to have wasted your time but i did glean some trouble shooting pointers from you all.
TY
