Dry VLAN possible?
Dry VLAN possible?
  Maybe a silly question but I am trying to accomplish a "dry" VLAN on a Meraki MX/MS setup.  By Dry I mean i'd like to assign ports to a VLAN and have traffic pass between those ports and devices connected to them but was hoping to not have to set an MX IP address or address scope.  Essentially having no interaction with Meraki MX, just a virtual cable if you will.
Regards,
-m
Accepted Solutions
Re: Dry VLAN possible?
This is an example of one I have done.  I tend to make the third tuple equal to the VLAN number.
10 REPLIES 10
Yes you can. You are forced to assign an IP but do not have to use it or enable DHCP on the VLAN. If I understand correctly you might want to just make a new VLAN and then assign it to a couple of ports set to access mode. You could create a 2 or 3 port switch this way with nothing routing through the MX assuming you don’t route anything to the VLAN IP.
I have used auto-conf addresses when doing this in the past (169.254.x.x/30).  This class of addresses are link-local and non-routable.
I like the idea of using a auto-conf address but i get an error when I try to save it.  It says the MX IP address is not in the subnet.
The error is coming from the flipped numbers in the MX  IP, you have 196, should be 169.
wow, rookie mistake. I stared at that several times too. Thanks for the catch.
Thanks Brandon!  I figured that might work, and I think that coupled with the autoconfig address it makes it a bit more "dark/dry" to Meraki.
You said you have a switch? Does the traffic actually have to transit the MX in order to do what you need it to do?
i.e. is it just internal or does it need to go out. If it doesn't need to go out, and all the ports are of the MS...
All the ports would be on the MS or multiple MS's.  So it doesn't really need to traverse the MX
If all on the MS, just set the ports to a unique vlan. No MX config required. Just make sure you add that new vlan to the trunks.
I do this at hotels all the time. They never make L3 changes, just add some made up vlan to the ports I need and trunk it for me
