Offline Warm Spare Resets Network?
arapheon
Hello everyone.  I had a interesting event while managing a client's network yesterday. And by "interesting" I mean unexpected and very frustrating.  I can't find any reference to it through googling and I'm wondering if this is isolated or a known/expected behavior.
I have a client that has two locations, each running with a single MX84 with redundant WAN connections.  They recently ordered two new MX84s to act as warm spares.  So while these devices were still in their box I added these devices to their inventory, then to their respective networks as a warm spare, and that's where the fun began.
The moment I added this (still boxed) device all network traffic reset.  Logs showed DHCP leases dropped, VPN tunnels reset, WAN connections reset, the whole package.  It only lasted for 20-30 seconds, but it took place at both locations separately, at separate times, the moment it was added.  Then the client said they wanted to use two different serial numbers instead, and the same thing happened when I removed the devices.
Maybe I missed it, but I didn't see anything about this in the HA Pair guide
MX Warm Spare - High Availability Pair - Cisco Meraki
Also, it just doesn't make sense to me that the device would behave in this way when presented with a spare configuration of a device that isn't even connected. No warnings, nothing.  Has anyone else experienced this?
7 Replies 7
DarrenOC
Hi @arapheon that shouldn’t have happened. Have you read through the release notes for the Mx firmware you’re running? Could be a known bug
When you  add a mx as spare the primary is going to use a new (vrrp) mac. I can imagine some things will happen in the active mx /network.  Cant tell what is expected or not.
arapheon
Don't know if it matters, but I am not using a virtual IP. Merely two separate public IPs. I would think that would keep VRRP from being implemented.
Paul_H
@arapheon VRRP will absolutely be implemented as this is the mechanism we leverage to elect which is the active MX. Do keep in mind VRRP advertisements are sent out the LAN ports only (once every second) as there is no guarantee the WAN ports will be able to communicate so they won't be sent out those interfaces.
As far as your initial post about DHCP/VPN drops, I would definitely open a ticket with support so they can validate the issues you're seeing and offer their expertise!
Hope this helps!
Aaron_Wilson
This has been in the known bugs for a while. Maybe it's this?
Known issues
  • After making some configuration changes on MX84 appliances, a brief period of packet loss may occur. This will affect all MX84 appliances on all MX firmware versions.
arapheon
Yes possibly. I would have hoped that adding a spare to the dashboard would save those configuration changes and/or packet loss for the time that I actually decide to add the physical device to the network. I love the simplicity of Meraki but there's certainly something to be said for the full granular control I'm used to with an ASA.
DanielBHSNIT
This is a very old thread but I can confirm that today, 9.21.2023, this happened to two of our networks when we added into inventory a 2nd MX appliance, we didn't even set it up as a warm spare yet and the network traffic reset.
