We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
Can Non-Meraki device will get the malware scanned by the Meraki when the IPSec Tunnel is formed ?
Solved! Go to solution.
https://community.meraki.com/t5/Security-SD-WAN/Client-VPN-and-AMP/td-p/97568
@KarstenI tested this
@endrianusgohan : AMP ( Advance Malware protection) is available only with Advanced Security Edition licensing and SD-WAN Licensing
https://documentation.meraki.com/MX/Content_Filtering_and_Threat_Protection/Advanced_Malware_Protect...
You can check the events
https://documentation.meraki.com/MX/Monitoring_and_Reporting/Security_Center
Hi @Inderdeep ,
yes, I know.
But my question is : I have cisco meraki with AMP license in HQ. I want to connect non meraki device to HQ using IPSec tunneling. Can the AMP from cisco meraki scan the non meraki traffic ?
