No connection to WLC
MarcP
I am using a MX65 in a location and got Cisco AccessPoints (AIR-CAP1602I-E-K9) in use.
When I sent an AP (factory defaults) into this location it is getting an IP but not connecting to my WLC here in the headquater. Before using Meraki, we used Cisco Router, where I needed to configure 2 udp forwardings and one helper-address.
If I´m doing the setup before I sent the AP into the location everything works, when it´s connected on-site.
As far as I see, udp forwarding is not the solution at Meraki, but I don´t find an solution and the support says I have to get in contact with Cisco, but don´t have a responsible person and also don´t understand what he wants me to do.
Tried it with dhcp option 43 as well, without succes.
Has had anyone this problem and solved it? Would be grateful for any kind of help.
Thanks,
Marc
NolanHerring
https://shimi.net/services/opt43/
You have your information criss-crossed
10.0.1.199 = 0a.00.01.c7 which means option 43 = f1040a0001c7
10.0.1.201 = 0a.00.01.c9 which means option 43 = f1040a0001c9
So in your case the DHCP option 43 will need to be set to "f1040a0001c9" and hopefully it will start working 😃
Nolan Herring | nolanwifi.com
TwitterLinkedIn
12 Replies 12
did you  make packet captures on the mx lan and wan and maybe looked what is blocked or not responded to.
MarcP
@ww:No, to be honest didn´t do that so far, but will do that today... But I´ll set up an Test location and do it there...
@NolanHerring
rhbirkelund
Try setting the hex value without colons. I.e. f1040a0001c9
NolanHerring
Can you provide a screenshot of how you have Option 43 configured?
Also are you able to provide the console output from the AP after you turn it on.
Might be worth trying to set up the port forwarding via the following guide using these ports. Not sure if this will work though.
https://documentation.meraki.com/MX/NAT_and_Port_Forwarding/Port_Forwarding_and_NAT_Rules_on_the_MX
ip forward-protocol udp 12222
ip forward-protocol udp 12223
ip forward-protocol udp 5246
ip forward-protocol udp 5247
TwitterLinkedIn
MarcP
Don´t know why, but in my test location it is working... using my default settings.
Does anyone know what the Value stands for? I can´t confirm it is the MAC address of the WLC...
rhbirkelund
Option 43 is not the mac address of the WLC.
It is the IP address of the WLC in Hex format.
See Cisco's document on option 43
https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/97066-dhcp-option-43-...
NolanHerring
Give me the IP of your WLC and I can convert it to the correct hex format
TwitterLinkedIn
MarcP
Old is 10.0.1.199 --> f1:04:0a:00:01:c9
New is 10.0.1.201 --> ?? can´t convert it to the correct format, always getting: "0a0001c7"
Can you provide an webpage?
rhbirkelund
TLV values for the Option 43 suboption: Type + Length + Value. Type is always the suboption code 0xf1. Length is the number of controller management IP addresses times 4 in hex. Value is the IP address of the controller listed sequentially in hex. For example, suppose there are two controllers with management interface IP addresses, 192.168.10.5 and 192.168.10.20. The type is 0xf1. The length is 2 * 4 = 8 = 0x08. The IP addresses translates to c0a80a05 (192.168.10.5) and c0a80a14 (192.168.10.20). When the string is assembled, it yields f108c0a80a05c0a80a14. The Cisco IOS command that is added to the DHCP scope is option 43 hex f108c0a80a05c0a80a14.
 [link]
In your case;
Type: 0xf1
Length: 0x04
Value: 0x0a.0x00.0x01.0xc9
Therefore; f1040a0001c9
NolanHerring
TwitterLinkedIn
Awesome link; hereby bookmarked. 🙂
MarcP
Thanks all for your help, its works now 🙂
