Moving MX to a different network
LeAnts
Hi All,
I need to move my MX from one network into a different network within the same organization.
As per documentation, this is possible however the downside is that I will lose my config and essentially have to rebuild from scratch?
has anyone done this before and found a way to move the MX and keeping their old config in place?
thanks in adv
DarrenOC
Hi @LeAnts , I’m afraid you’re right in that configuration will be lost whilst moving your MX between Networks:
https://documentation.meraki.com/General_Administration/Inventory_and_Devices/Moving_Devices_between...
It’s a simple process which I’ve performed a number of times. Either use the APi to retrieve the existing firewall rules etc. or use a manual process of noting all the config prior to moving.
LeAnts
Cool thanks.. yup will just redo the config.. luckily not much as MX is not live yet.
GreenMan
Meraki Alumni (Retired)
Remember that, when you create a new Network, you can use an existing Network to form the basis for your new Network, via cloning  https://documentation.meraki.com/General_Administration/Organizations_and_Networks/Cloning_Networks_...
@LeAnts if you are moving it into a combined network you can simply split the combined network into its components and then join together the bits you want.
For example:
Existing network A consists of Switch Network A, Appliance Network A and Wireless Network A, but you want to get the MX that is in Appliance Network B
Split network A
Combine Switch Network A, Appliance Network B and Wireless Network A into new Network A
TaDa!
