Meraki external route not working.
Rsharma
I have a FortiGate firewall in front of my Meraki MX appliance. FortiGate has site to site IPSEC tunnel with one of our DC and Meraki is the Hub for auto VPN setup for my other sites. i am getting some routes through Firewall IPSEC and those subnets are reachable through Meraki Hub. but when i advertise those learned routes into auto VPN my spokes cant reach those subnets though. when i try to trace these subnets instead of taking me to the auto VPN route shows it is taking the default route. is there any advise?
reachability though MX Auto VPN Hub.
Route being recieved on spoke via auto VPN.
no reachability from spoke LAN switch.
7 Replies 7
rhbirkelund
Is the Fortigate IPSec tunnel is terminated on the same MX that is working as Hub in AutoVPN? If so, Meraki unfortunately does not support routing between Third-Party VPN and AutoVPN.
It you need to route between Spokes sites on Meraki AutoVPN and the Non-Meraki VPN, you'll need an extra MX.
@rhbirkelund remote tunnels are terminated on the fortiGate. MX only has auto VPN tunnels and routes to reach remote subnets pointed towards fortiGate.
Is the spoke lan switch/ip from a vlan (management vlan?) that is selected to be in the autovpn?
Rsharma
@ww yes switch IP belongs to management subnet which is routed into autoVpn.
KarstenI
Can you draw a picture with some example networks?
And have you the NAT-Exemption enabled for the MX?
At least when the Fortigate is in front of the MX, all traffic flowing to the Fortinet would be NATed by default which can cause problems and make this really complex.
I would put the MX in concentrator mode or place them side by side instead of behind the other.
Rsharma
@KarstenI here it is. this network was handed over to me as it is 😞 . i am able to reach both 10.50.x.x and 10.60.x.x from LAN subnets of the hub. i am advertising these routes in auto VPN as well but spokes cannot reach DC subnets though.
Are that subnets  green in the routing table on the spoke?
From the hub you can ping the switch ip of the spoke ?
There are no sitetosite vpn firewall blocking traffic?
