I'm using the Meraki API's from a Google Sheet to get additional metrics. However, I can't seem to find and/or if a report exists for WAN2? I am using the API report under "Org Wide" then "Device Uplink Details"
It gives me the status of WAN1 whether active or not or if an ip address is not defined.
Does this report or data exist somewhere for WAN2?
The business use case is WAN2 is often our 4G failover and/or a slower connection alternate vendor to WAN1 but want to make sure the back is operable.
