Meraki MX68 Features Supported
LeAnts
Hi All,
looking to purchase a mx68 with advanced security licensing for a small office location..
from the list below.. please can you tel me what is and what is not supported - the datasheet is very limited.
SSL VPN tunnel - yes but requires a anyconnect license? or covered by the advanced security license and how many users?
DLP  - cannot see specific data pertaining to the mx68?
Web filtering - supported yes but limited cannot do custom profiles etc that i am aware off.
WIDS (wireless intrusion detection) supported?
thank in adv
2 Replies 2
Brash
Hope this answers your questions:
Remote access SSL VPN: Requires Any connect licensing separate from Advanced Security
DLP: Not a feature of the Meraki MX. You would deploy in tandem with another security solution.
Web Filtering: Layer 7 rules and content filtering is supported. More limited than a NGFW however
WIDS: The MX does support IDS/IPS or traffic through it but no additional WIDS capabilities
If all of those are a must have, it might be worth looking into Cisco Umbrella integration and Cisco Any connect for a full SASE solution (Cisco Secure Connect)
You can create group policies with content filtering and layer 7 rules, and apply them to specific machines or VLAN interfaces.  This needs an Advanced Security licence.
https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Creating_and_Applying...
You really want to use a Meraki MR axxess point if you want strong features in this area.  They support Air Marshall.
https://documentation.meraki.com/MR/Monitoring_and_Reporting/Air_Marshal
The WiFi built into the MX models is very basic.
ps. The MX68 has two PoE LAN ports - so you can plug an MR directly into one of the PoE ports to power it.
