Is there any risk if I do SSO logon with Meraki that I get locked out, or do the other built-in Administrator accounts still work?
Solved! Go to solution.
Local accounts still work. In fact there has to be at least 1 local account for a dashboard Org to even exist.
Built in administrator accounts will still work as usual.SSO accounts will actually login using a slightly different portal URL (specified as part of the setup).
Thank you all. That is what I needed to read. This looks easier than the Green Lake HPE Aruba I just setup in DUO
