Meraki MX Design & Config
Raji
What is the protocal begin used for to build the tunnel in MX devices ? and how tunnel co-relation are there or how many tunnels we can build over MX security series devices ?.
You can take a look at the meraki autovpn whitepaper
https://meraki.cisco.com/product-collateral/auto-vpn-whitepaper/
Also check the sizing guide for recommended tunnel count
https://meraki.cisco.com/product-collateral/mx-sizing-guide/
4 REPLIES 4
Raji
Thank you for sharing this.
DarrenOC
Just to follow on from @ww ’s awesome reply - the number of tunnels will depend on your design.  Are you looking for full mesh (hub) or site to site (spoke)?
The calculations to work out each can be found in the below document
https://documentation.meraki.com/Architectures_and_Best_Practices/Auto_VPN_Hub_Deployment_Recommenda...
Thank you for sharing this document.
