Meraki Firewall Settings
Just browsing
We have a Meraki MX100, and we have set a firewall settings on Layer 3 and enable specific ports and lastly deny others. I have a mobile app Hik connect and view IP camera in other offices. But after Firewall settings we are unable to view ip camera video. Can anyone tell me the port number which i should enable and view through mobile apps.
Regards
Palash
Palash
6 REPLIES 6
Re: Meraki Firewall Settings
Do you have an exact model for the camera?
Just browsing
Hik Vision NVR Model: DS-7616NI-E1
HIk Vision IP Camera Model: DS-2CD1230 and DS-2CD1331-I
Palash
You should ask the people you got the camera from what the firewall requirements are.
I'd have a look at the manual that came with the camera, differnet brands and different models even can use completely different ports.
Most use RTSP or HTTP but some vendors use non standard ports for these.
Just browsing
I have already asked the people who delivered the camera and suggested the ports (8000,554,8200) are allow and we did it but we can't view my mobile through HIk Connect Software. But If I allow all in firewall settings then we can access.
Palash
Although the documentation is not very clear I find 80, 8000 and 554 here:
https://www.hikvision.com/ueditor/net/upload/2015-06-10/3b56a0c6-f61c-4381-866e-dc49e5c30c88.pdf
and here:
http://specsheets.dvs.co.uk/Hik%20connect%20-DVS.pdf
For local access from another subnet in your network it's those ports that you'll have to open up.
For remote access from the internet, there are two options:
  • Either you setup port forwarding for those ports. Note that forwarding port 80 means that the MX's local web page may not work anymore. You could use an alternative port as they do in the first pdf (they use 8008 instead).
  • Or you setup 1:1 NAT if you have a free WAN IP. Make sure you close off the firewall and only open up those three ports.
If there's a NAT router in front of the MX you'll need to configure forwarding in that too.
