Hi Community,
Did anyone meet this issue below? or anyone can help with this issue.
I have two Meraki Sites: Site A and Site B. Both Sites I have setup Client VPN with IPSec. The Client VPN is working well when you are at Home or at any other places except on another Meraki Site.
For example, Clients on Site B try to connect Client VPN of Site A, the connection wont' be built up successful. Same issue clients on Site A try to connect Client VPN of Site B, the connect won't be built up, normally it comes with this error below. This issue only happens on a site that is on Meraki Network, both clients VPN is working at home.
On Site A I enabled Site-to-Site VPNs, but on Site B Site-to-Site VPN is not enable, not sure if the Site-to-Site VPN could cause any issues.
Any ideas? Thanks.
Regards,
Marlon
