Maximum vlan ( limit ? ) on a MX
RaphaelL
Hi there ,
We have a setup that requires 500+ vlans. Currently we are using MX84/MX85. However when we bind the MX to the template , they can take up to a week to come online. We tried with a MX250 and it took 25 minutes.
It can't even "fetch" the config which is weird. I could probably create 1000 vlans on pfsense running on a RPI1 , I don't see why a MX85 couldn't do that.
Has anyone ever tried a large amount of vlans on a small/medium size MX ?
Yes we did open a case.
10 Replies 10
Wow, why so many VLANs?
RaphaelL
The design is questionable ( I 10000% agree ). Something like 85 floors / 6 vlans per floor.
It's a stupid design but I have to get it working. 😤
Ryan_Miles
Meraki Employee All-Star
With that amount of floors & VLANs what is the expected client count? I'd have to imagine something way higher than a MX84 or MX85 can even handle from a flows perspective.
RaphaelL
Currently 200 clients.  We have to provision the vlans even tho there might never be any clients in that vlan.
So the MX85 is checking all the boxes performance wise.
Ryan_Miles
RaphaelL
Our large campus are all defined the same way. We made "molds" or templates so that one size fits all.
Why so few clients ? Well this MX only routes "external" vlans ( non corporate assets ).
6 vlans ? 1 for HVAC , cameras , IOT , and so on. And these devices are not present on every floor but in the case that a new installation would require a device to be placed in the IOT vlan , that vlan would already be present. That's why. Not my design. Frankly it's trash , but I have to live with it a couple more months.
Anyway we are getting side tracked.
A brand new MX85 out of the box can't even load the dummy config.  We tried 100 vlans, takes 10 mins. 200 vlans takes 30-60mins. 300 even more and to a point that the MX doesn't even come online.
Even a "beefy" MX250 can take 10-20-30 minutes to load a simple config with many vlans. Engineering is going to repro this in their lab next week. So I will get some answers.
The only thing that I know is that you can only have a maximum of 255 VLANs configured on MXs in HA. - Dashboard will not stop you from going beyond 255 but will break things if you do. This is a known bug and dev team is looking into a long term fix on this one.
Ryan_Miles
SImilar to what @alemabrahao mentions above regarding the HA scenario there are cases in which large numbers of VLANs create performance issues on MX models. The general guidance appears to be no more than 100 VLANs as mentioned here.
Interesting!  I've never tried.
I bet this is something solvable by the dev team - if they are motivated.  Unless it is some dumb silicon restriction (maybe they have to register the VLANs they are interested in with the silicon, and the more VLANs the slower the silicon gets at adding them).
Have you tried experimenting with different firmware versions?
RaphaelL
Good point. I'm testing with 18.1 and a lot of increase in performance with 18.2. Might be worth to try
