We are new to Meraki Firewalls and are attempting to understand how to create particular bandwidth pools for clients to limit VoIP issues.
We currently have 2 WANs, a 50/50 Fiber (for clients) and a 50/10 Coax (for backups).  We are not load balancing and the office has 55 users.
We originally attempted to allow unlimited use per user setting our SIP voice to High priority, DSCP tagging it as Real Time, and setting everything else as Normal but found that this maxed out our bandwidth causing VoIP issues.
We have also attempted to add a per client limit below our bandwidth maximum but found that even allowing more bandwidth than our VoIP system requires we still had VoIP problems.
We have begun using the per client limit in the MX84 and have found that this eliminates the VoIP and bandwidth issues but this also severely limits users as we cannot apply enough bandwidth per user for acceptable internet use.
With our last Firewall we were able to limit users to pull from a bandwidth pool that was below our maximum bandwidth capacity to guarantee that VoIP would always have bandwidth.
Does the Meraki allow for this?
