Limit bandwidth for wired clients
Captain
Dear Community,
How can I limit bandwidth to 5Mb/5Mb per each connected client over wired cable for a specific vlan?
For wireless clients there's a manner doing so by going to Wireless -> Configure -> Firewall & traffic shaping -> Traffic shaping rules -> Per-client bandwidth limit ->  Set desired values ...
For wired clients I can't find where to configure.
Best regards,.
jdsilva
Huh... OK, I'm not really clear from the docs if this will do what you want...
My example above stands for per-client rate limiting on a VLAN, but to aggregate the entire VLAN into one maximum... I would try this under Security & SD-WAN > SD-WAN & Traffic shaping:
The doc here:
https://documentation.meraki.com/MR/Firewall_and_Traffic_Shaping/Traffic_Shaping_a_Local_Subnet_or_H...
Seems to indicate that this would provide per-VLAN rate limiting.. But I can't say I've ever tried this. We just limit per-client using the method I posted above.
Maybe someone else can confirm or deny if the Traffic Shaping policy works?
8 Replies 8
kYutobi
That can't be done on the wired side unless you have a MX to do this in the SD-WAN and traffic shaping.
Enthusiast
Captain
I do have.
Can you please share instructions as per my specific needs?
Best regards.
jdsilva
Hi @Captain
You can do this by applying a GP to a VLAN on an MX network.
Created your GP under Network wide > Group policies with a rate limiter:
And then you can apply the GP to a VLAN under Security & SD-WAN > Addressing & VLANs:
Captain
Okay.
Sorry this is not clear:
The limit set in Bandwidth -> use custom bandwidth limit
 Is applied per entire vlan ?
 or
 Per each client connected in that vlan?
To me it seems like it is per entire vlan... I am looking for how to limit per client in a vlan.
Let's say I have a vlan called "wiredGuests" with vlan id 100 or whatever...
I would like to limit that entire vlan to 10/10 Mb
 and for each client within that vlan wired connected - as well limit to 1/1 Mb
Best regards
jdsilva
@Captain The method I presented will limit each client on that VLAN to 5Mbps (both up and down). It will not limit the entire VLAN to 5Mbps.
I think that's what you want?
OK, sorry, that's a bit different. the VLAN to 10/10 with clients to 1/1 wasn't in your original post. That can be done, one second...
jdsilva
The doc here:
kYutobi
Thanks @jdsilva for the assistance. I got busy with a switch here and couldn't get to @Captain
Enthusiast
Jeizzen
I just opened a case to have that clarification
And Meraki confirms that Bandwidth limit that is either applied by Group Policy on a vlan or applied by Traffic Shaping rule on a subnet is a per-flow/client limit, and not an entire vlan/subnet limit.
The only way to apply a ' per-vlan ' limit is on an SSID
