Limit bandwidth on guest wifi on MX
alceryes1
Hi all.
(see pic) I'm looking to limit the bandwidth of users on my guest wifi. It looks like the only way to do this on an MX is by using the group policy function. Does this look right to limit my guest wifi (Guest Wifi IP range obfuscated) to 25Mbps?
TIA!
alceryes1
NM. Found the right section. I totally missed seeing the custom expression in the traffic shaping rules. You just have to set it to the IP range you want to limit -
alceryes1
Initial testing shows that the group policy setting above does NOT work. Maybe it's configured wrong...?
Or, is there some other way to limit the bandwidth on just the Guest WiFi (which is a separate VLAN).
alceryes1
If this is a Meraki WiFi solution, then you can go Wireless/Firewall & Traffic Shapping, select the correct SSID, and then configure the traffic shapping.
alceryes1
This option does not appear to exist on Meraki MX sppliances with WiFi. It's only available on dedicated Meraki APs (MR devices).
