MX64 - Client VPN - NSLOOKUP - Shared Netwok Drive
iReidy
Summary
I have setup my Client VPN and Users can connect OK however
Users cant connect to one of my network drive but can connect to the others?
NSLOOK Unknown Server?
Cant connect to a local web address?
More Info
Clients connect OK, we have a couple of shared drives across two servers,
they can connect \\AWA01\example1 = M
they can connect \\AWA01\example2 = N
they can not connect \\awa02\example3 = O
* these drives connect OK when Users are on the local lan
* If they click on O they get the following error - An error accured while reconnecting O:
ALSO
We have a server running some specific software and on the VPN we can't connect to the URL
ALSO
If I ping the servers I get a responce
If I do a DNS LOOKUP I get the following
DNS request timed out
timeout was 2 seconds
Default Server;: UnKnown
Address: 192.168.10.19
MERAKI MX64 VPN
Client VPN Server: Enabled
HOSTNAME: ONE-************ I have hid this ********
Client VPN subnet: 192.168.12.0/24
DNS nameservers: Specify nameservers
Custom nameservers: 192.168.10.19 and 8.8.8.8
WINS: No Wins server
Secret: ****I have hid this******
Authentication: Meraki Cloud
AndrewR
You'll want a rule that looks something close to, if not exactly like, this. The only part I am making an assumption on for you is the destination IP. I assumed your DNS server IP to be in the same subnet as all the file servers you are trying to access.
For troubleshooting, place this rule first at the top of your firewall rules list. Hit Save. Wait a minute or two for the config the update, and then test it out. You may need to reboot the vpn client, and/or disconnect/reconnect the vpn client for all settings to apply. Remember that this is an allow-all rule, which is ideal for troubleshooting, but you may want to make it more restrictive after you confirm what is causing the issue.
AndrewR
My initial reaction is that the issue is at the firewall (Security Appliance --> Firewall), and the Client VPN subnet is not being granted access to server O and the URL you spoke of. I would double-check firewall rules first, making sure the proper exceptions are in place. When I first launched our client VPN I could not connect to anything on the LAN because it was all being blocked by the firewall. I had to then go insert some Allow exceptions.
For troubleshooting and to quickly prove/disprove this theory, you could put an Allow-All from VPN to LAN rule in to see if that clears your errors immediately, and if so, can then go back and adjust your rules to be more prescriptive.
I'll be curious to hear if that changes anything for you.
iReidy
Thanks for the reply, I couldnt see where to add this in the firewall.
Could you kindly point out which bit I add to the firewall.
AndrewR
iReidy
Thanks that worked, I'm new to Meraki always used Draytek.
Gratefull for you taking a look and helping solve my issue.
