MX84 and LACP
JSA
MX84 and LACP
I have 1 MX84 and 2 downstream Huawei switches - is LACP still unsupported on the MX ?
Correct.
JSA
Thanks Philip.
Therefore, the proper way is to have 2 units of MX84s - each connected to one downstream core switch which is configured in a HA setup ?
Bruce
Since you talk about using LACP I assume the two Huawei switches are stacked. If this is the case then make a connection to each switch so that if one switch fails a connection to the other will still exist. The Huawei switches must be running spanning-tree, and one of the ports on the Huawei stack will get put into blocking state - the MX doesn’t participate in spanning-tree, it just forwards BPDUs. Hope this helps.
