Understanding VRRP Logs and Transitions
Craiegg
Hello all,
i've been working on a few Meraki devices and I've seen some failover events come through. I would like to understand the logs better.
Security appliance Client Event type Details
Time (UTC)
Sep 29 15:31:01MX001 VRRP transitionif_up: 0, old_if_up: 1, mode: detect
old_modedetect
prio75
old_prio255
elector_statebackup
Sep 29 15:26:05MX001 VRRP transitionif_up: 1, old_if_up: 0, mode: detect
old_modedetect
prio255
old_prio75
elector_statemaster
My Objective: Identify when the primary failed and switched to being a Backup.
Could someone help me understand the status codes in the Details section. I have read through the Routed HA Failover Behavior. But I do not understand the Elector state .
Is it saying Elector State- Master = Device is currently Master
and Elector State - Backup = Device lost connectivity and is now Backup ( Spare becomes Master)?
Could someone please clarify the same for me. Would highly appreciate it!
Thanks,
Craig.
CptnCrnch
Exactly:first, it had a priority of 255 and was acting as VRRP master. Then it looks like its uplink failed, therefore it transitioned to Prio 75 and went into Backup state.
4 REPLIES 4
CptnCrnch
@CptnCrnch that indeed did help and i appreciate you referencing the link too.
However, what I am not understanding is the section Elector State - Master / Elector state - Backup
As per my reading of the link and understanding - 255 for Primary is Master and anything below that is Backup
As per my logs at Sep 29 15:26:05 MX001 - transitioned into Master as Prio is 255 and then at Sep 29 15:31:01 MX001 transitioned into Backup as Prio is 75.
Can you confirm that my understanding of this is correct?
CptnCrnch
@CptnCrnch
That was helpful and quick. Thanks a lot for clarifying my doubts! Much appreciated 🙂
