MX75 GPON SFP
burnz
MX75 GPON SFP
is there any way to use a GPON SFP within the SFP Port auf the MX75 or other MX?
The Datasheet only mentions the Meraki SFP, but I already used others with the Switches.
https://documentation.meraki.com/MX/MX_Overviews_and_Specifications/MX75_Datasheet
I would like to use it on my Telekom FTTH with a module like this:
https://geschaeftskunden.telekom.de/internet-dsl/produkt/digitalisierungsbox-glasfasermodem-kaufen
5 Replies 5
CptnCrnch
The SFP will probably work flawlessly, but opening a case that has something to do with it could take longer than expected.
DarrenOC
As @CptnCrnch states any number of Sfps will work but you’ll be asked to remove it by Meraki support should you hit an issue.
MerryAki
Hey burns, I have searched for a post like yours, actually, my first MX is on the way (for my homelab)
It is possible!
As I want to replace the current setup with an MX, I will keep the Zyzel/Digitalisierungsbox Modem. It works flawlessly. All you need to to is to change the line ID, call the Telekom support for rediscovery and that’s it.
Telekom contact for rediscovery/site for the order process:
(You will then need to use VLAN 7 and PPPoE, but thats mentioned in the link below)
Actually, I read this online, too.
https://blog.jaseg.de/posts/telekom-gpon-sfp/
And there is my post on a german speaking Ubiquiti Forum:
I will add some screenshots when my MX is there to the rescue 🛟
burnz
Short update i bought the Zyxel/Digitalisierungsbox SFP and placed it in MS220-8P and it works like expected I'm able to access webinterface for configuration and so on.
As I'm still on MX67 I expect that this will work too when i do the change.
MerryAki
@burnz @That’s Great. Another option you might have is that you can bridge VLAN 7 from the SFP/SFP+ Port to a RJ45 Port and connect it with the MX.
I know, that’s ugly, but it might be a short-term workaround, while you’re not having a Port for that module.
