Hi All,
(Flame free post please)
Since updating my MX75 to 18.211.2 I have noticed the fan ramps up randomly to quite a high speed, and then back down again. Sometimes for many seconds, other times, just a few. The firewall isnt being taxed at all.
It's only an issue because it's in my lounge - (lets not going into that here :-D)
I am assuming that the "Significant performance improvements" in the "what's new" document is the cause of this?
Would be nice to see CPU usage to match that against fan ramp up - probably a support ticket time.
Anyone else noticed this on their 75? (either in a cabinet or the lounge. 😄 )
You need to open a support case, they will investigate it.
Likely a software bug but as mentioned open a support ticket for them to investigate.
Also see if it needs it's annual dusting 😂
Haha - its clean - although the vents on the MX75 are pretty small.
Summary Report - This network doesn't report anything unusual on the device utilization ?
Good call.
Seems quite high considering no-one is home during the day.
Seems to have settled down. Odd.
Ill see what it does tonight, then open a case. (device has been rebooted)
That looks like something that maxed out 1 CPU core, causing it to get hot.
I'll take a punt - software bug. I suspect if you do nothing a future update will sort it.
Seems like it. It actually started doing it when I took it to 19.1.3 because I like living on the edge, however I don't like living with a fan running that loud, and it's a real high pitch too. Rolled back to the latest stable (18.211.2), and the "problem" followed.
What does your CPU load look like? As seen above, I've been running 19.1.3 for over 2 weeks.
Funnily enough I have an MX75 at home in my lounge room.
There is something from that general area that spins up its fans for about 2 seconds and dies down again once or twice every afternoon/evening.
I haven't isolated that it is definitely the MX75 (it could be the MS220-8 or the Xbox) but I thought it was worth mentioning as it seems match what you're seeing
Thats the one. The only load on it might be streaming netflix or youtube, which is about the extent of it in the evenings.
My MX75 is in the hallway and I haven't noticed that behaviour, but it is running 19.1.3 and has a very low reported utilisation:
As for the MS220-8P, I don't think I've ever heard my one of those make a significant noise, so @Brash I'd be surprised if it was that!
Interestingly, you can see the load drop when I upgraded from 18.107.10 to 19.1.3 late on 31st May:
That should be because of the better use of resources/performance upgrade starting from 18.2 and up
Whats odd is you all have your MX is living areas, come on guys wheres the full network cabinet with structured cabling? We aren't savages 😂
I had to leave it behind when I moved house, and the wife hasn't let me channel the walls / rip up the floorboards in the new house yet... 😈
It's next to the ONT, which happens to be in the lounge, mounted on the wall. 😞
Utopia is to move it all into a cabinet into the utility room in the house where the washing machine, chest freezer etc are.
That being said, the fan spinning up is different behaviour to previous firmware versions.... Im launching a support ticket.
Unfortunately renting a place with a very humid garage and little to no structured ethernet cabling means all the gear sits in the living room ☹️
Old house's structured cabling with cabinet door open...
Case 11852289 / Will update here once I have some feedback.
OK - I clearly missed this in the known Issues list for the "stable" firmware updates
[Known Issues - November 20th Update] Due to an MX 18.2 regression, MX75, MX85, MX95, and MX105 appliances have significantly increased device utilization.
I'm also curious about how ready this version actually is:
Not really feeling the Meraki love with firmware updates on this one.
I don't know what firmware version you are reading but these issues were fixed months ago ( MX 18.207 )
MX 18.211.2 is the latest.
*sigh* yeah - you are right. Not sure why that happened. Thanks for correcting me.
However - still doesnt fix my fan and utilisation - still waiting on feedback from support.
