MX68W
Eddie01
MX68W
I have a question regarding the MX68W, can I add AP's to the MX68W. I ask because I have a site that has a MX68X and now that want to use the LAN ports on the MX.
Regards
DarrenOC
No you can’t.  They won’t behave as part of the same wireless network. Ie seamless roaming
6 REPLIES 6
Inderdeep
@Eddie01 : yes you can use LAN ports to Access points connectivity
https://documentation.meraki.com/MX/MX_Installation_Guides/MX67%2F%2FMX68_Installation_Guide
Regards/Inder
www.thenetworkdna.com
But will the wireless on the 68W have any issues with the AP's
CptnCrnch
Possibly, as they don't share any info with other "standalone" APs you're configuring on your Dashboard. Fortunately enough, the standalone APs are quite intelligent, so there shouldn't be any issues.
Thanks Guys
It should work fine when you bridge traffic. And disable rogue ap features.
However i would not recommend mixing  it for customers.  If something is wrong troubleshooting wont get easier.
DarrenOC
Community News
