MX68CW | Appliance Type Network | Configuring SSID
There are options available to Enable/Disable SSIDs 1, 2, 3, and 4. Is there any endpoint that can be used to configure SSID in an Appliance Type Network? Any Insights Appreciated.
Hi PhilipDAth Thanks for reply, if this is the path of configuring SSID through the UI, then actually I already know that. I wanted to find an endpoint that can be used to do it while using it as an API
Hi @Inderdeep@PhilipDAth Thank you both for the reply I think the solutions both of you gave are configuring it from the UI, actually I know the configuring SSID from the Meraki Portal, but I was trying to find an endpoint which can do the same when using meraki API. I already know https://developer.cisco.com/meraki/api-v1/#!get-network-wireless-ssids but this only works for Wireless Network Type, Is there any that can be used to do it from the Appliance Network Type.
Welcome to the Meraki Community! To start contributing, simply sign in with your Cisco account. If you don't yet have a Cisco account, you can sign up.
