SD-WAN - default route checkbox
whistleblower
hi guys,
I‘ve a question regarding the auto-vpn default checkbox on a spoke mx!
does this setting mean, that the default route is always present in the spokes routing table or will it go inactive if some communication problem between the hub&spoke occur?
if the route will “time out“ is traffic than routed/natted over the local internet (gateway route) access?
2 Replies 2
Yes its always present. It can go inactive and use another default route from inside the tunnel.
But it doesnt  fall back to local internet
Inderdeep
