MX68 as Router and Z1 as passthrough L2 Switch
ainfinity
I upgraded to MX68 and wanted to see if I can  use original Z1 router as just wired switch (Wireless disable) using  passthrough mode. Is this supported. It should work.   Can you guys confirm if this is OK
KarstenI
As already mentioned, this should work. But you need to put them in different dashboard-networks as there is only one appliance per network. I would go for a MS120-8 or if it has to be cheap, for an unmanaged 8-port-switch.
5 Replies 5
Inderdeep
Yes you can do that. Have a look on the below document
https://documentation.meraki.com/MX/Networks_and_Routing/Passthrough_Mode_on_the_MX_Security_Applian...
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
BrandonS
I’m not sure the point of using pass through mode to accomplish this, but you can disable wireless and probably most importantly you want to disable DHCP. Keep in mind you will still need the license for it to operate too.
ainfinity
I want to use the Z1 as a switch in other part of the home.  Where most of my  wired devices exists like : NAS server, Printer etc. MX and Z1 cannot be used as router in same set up.
KarstenI
ainfinity
Thanks. Yes. I plan to put Z1 in another  dashboard network.  This has been helpful.
