MX67C - Integrated Cellular not connecting
Tobias_Kuhnert
hi guys,
we're currently have issues with some MX67C devices and the integrated cellular.
I insert the SIM card (no PIN required), power up the MX, enable the integrated cellular, but nothing is happening.
We already did a lot of tests... like using different SIM cards, configuring the APN, and others... but for now it looks like that it is related to the devices itself.
This is the output of the "Uplink" tab:
I can't see anything in the eventlog either.
Did someone experience similar issues with the integrated cellular modems of the MXs so far?
Best regards
Tobi
20 Replies 20
only on some mx devices? the mx is already online using a wan port? running latest firmware?
Tobias_Kuhnert
yes, there are models, which are working and some are not.
We already cross-swapped the SIM cards, but that's not helping. So i tend to say there are some MXs, which have an issue with the cellular connections...
Yes, they did have an active WAN port.
lateste stable and beta firmware was tested. same result.
superfly
The cellular will not kick in unless the Internet port is not active.
However I see the following when I look at my MX68CW's
Cellular says ready. But as mentioned, it will never be active unless the Internet cable is disconnected - which is an issue if you see my post
https://community.meraki.com/t5/Security-SD-WAN/MX68CW-Cellular-doesn-t-work-if-Internet-port-is-act...
SoCalRacer
1 - MX needs to be connected via WAN port 1st to get firmware updates.
2 - WAN can't be plugged in otherwise cellular won't be active
Hope that helps!
Tobias_Kuhnert
Hope that helps!
1. ok... i know, but firmware upgrades are not the problem
2. i know that LTE is only backup, but we're not even getting there yet, because the device is not even trying to connect to the cellular network.
if i unplug the WAN, the MX is simply offline
SoCalRacer
Have you verified cellular coverage in the physical are the MX is located in?
Tobias_Kuhnert
yes - i have a LTE connection with multiple smartphones and my notebooks cellular on site.
SoCalRacer
To summarize:
You have some MX67C working and some not working with the same provider SIMs
You know you have LTE coverage where the MX is
You don't have this issue with any MX68CW
Questions:
Are these recently deployed?
Have you checked the config log to see if anything stands out or is different from the working ones?
Is a factory reset an option on a test 67C?
Ben
Which carrier are u using?
Tobias_Kuhnert
Mainly Telekom, but we also tried with O2/Telefonica
btw. we're talking about a deployment in Germany
SoCalRacer
It almost sounds like you have the North American model and not the Worldwide model.
Another thing to test would be a usb modem with that sim plugged into the MX67C
Tobias_Kuhnert
We ordered the WW model and also dashboard tells me it's a MX67C-WW.
However, it really looks like this is something, which can only be resolved by meraki support. i was just curious if somebody else experienced any issues with the integrated cellular too.
MD30
We are having the same issue on 1 of our MX67c-NA trying to connect to Verizon.  Have setup several of these so far without a problem.  verfied a strong cell coverage standing right next to MX.
Ben
Telefonica is listed, so if your sim pin is deleted it should connect.
Under "Cellular Interface" supported carriers are listed.
https://documentation.meraki.com/MX/MX_Overviews_and_Specifications/MX67_and_MX68_Overview_and_Speci...
NinHo
we had the same issue with just Verizon.  had to upgrade to 14.53 firmware and enter the correct APN on the dashboard.
superfly
Sounds like you should log a case.
CptnCrnch
Did you succeed finally? I had a similar experience today (same provider). LTE came up only after powering off the MX completely and is running fine since then.
emarosi
I have a similar issue too.
MX67C cellular is not connecting even with correct APN and signal is full strength.
When WAN connection is removed the device goes offline.
LED is orange
JohnnyB
I am having similar issues with my MX68CW but only when I have the ISP (Verizon) enable the Static IP.  If I have Static IP disabled, it actually connects fine with no issues but i am then limited to just internet connection and cannot Client VPN.  I also have the correct APN and still no luck.
Check to make sure the carrier has Static IP disabled for that specific SIM, and see if it would connect then..
JohnnyB
I just realized there was a firmware update on my MX68CW and just had it upgraded to 15.27 and seems to have fixed my issue.. maybe take a look and see if there are any new beta firmware you can try upgrading to.
