I've never setup 1:1 NAT. So now I just tried the following.
http://www.macfaqulty.com/filechute/Firewall_Configuration_-_Meraki_Dashboard.png
I've inputed the IP of the WAN, but when I click "save" it tells me...
There were errors in saving this configuration:
- 55.66.77.88 (not real IP obviously) is the primary IP address of Internet port 1 and cannot be forwarded.
Hmmm... not sure why this doesn't work.
Vonage's page indicates that the following should be disabled:
1.SIP ALG and/or SIP Transformations
2.VoIP-specific Functions (see #1)
3. SPI or DoS protection (disable or allow more connections)
I also found this page  where the person wanted to change the UDP Timeout value, but you can't on the MX64. Suggestions wouldn't work for Vonage. I really think the solution is to ditch Vonage. lol
