Hi
Has anyone in Australia got a USB modem working on a MX64?
I'm connecting to the Telstra network using a custom APN to get a public IP address assigned to the modem.
From the supported modem list https://documentation.meraki.com/MX-Z/Cellular/3G_-_4G_Cellular_Failover
I have tried the following
Sierra Wireless AirCard 320U This modem isn't detected on the MX64 but is detected on a MX60
Huawei E3276s-150 Detects and connects but the connection speed is very slow. Modem works fine on a PC.
Was told by support the Huawei E3372s-153 were very good. Was able to get one but it's a Huawei E3372h-607 (Box only had E3372 on it) This modem works great but the HiLink mode that it runs means it runs in a router mode and has it's own private ip so port forwarding will not work and this is a requirement.
I'm into the 4 month of trying to get this solved. We have also tried beta firmware V13.x and V14.x with no success.
Hoping someone has a suggestion.
