MX64 Secondary DMZ
JeroenK
MX64 Secondary DMZ
Hey All,
I have a question regarding the capabilities of a MX64. On the site it says that it is capable of creating a DMZ. Is it also possible to create 2 DMZ networks and a LAN network. And where can i set this up?
And is it possible to route traffic based on the URL that is chosen?
Thanks in advance,
Jeroen
2 Replies 2
Adam
This article has the instruction on configuring the DMZ.  https://documentation.meraki.com/MX-Z/Firewall_and_Traffic_Shaping/Creating_a_DMZ_with_the_MX_Securi...
Routing for things is destination based so you'd have some control over that.
A DMZ is effectively just another VLAN.  In Meraki these must use private IP addresses, and you have to NAT any public IP address and/or port through to the internal device.
