We're migrating to the Cisco Community on March 31. The Meraki Community will enter read-only mode starting on March 26 through March 31.
Because MX doesn't support LAG, so can connect two links between a MX and a switch? like switch spanning tree to block one link? Anyone please advise, thanks in advance.
Solved! Go to solution.
@Qing , the MX will pass STP, so if you connect two links between an MS and an MX the MS will block one of the links because it sees its own BPDU.
This will be an interesting topic for you.
https://community.meraki.com/t5/Security-SD-WAN/How-to-cable-MX-amp-MS-for-HA/td-p/22765
@BrechtSchamp they have even udated the documentation to use the method I was recommending in that article.
https://documentation.meraki.com/MX/Deployment_Guides/MX_Warm_Spare_-_High_Availability_Pair#Recomme...
Thanks a lot for everyone's kind reply.
