HA Warm spare failure detection
MerakiLover
Hello guys,
I've a question concerning this:
how can I monitor / be alerted if a warm spare device fails?  Is there something in the dashboard to setup for being warned about this?
Is is possibile to do it via snmp either?
I'm not talking about the primary mx fail so that there will be a failover but I'm talking about the secondary idle MX that fails.
Thanks a lot
jdsilva
You should be able to use the security appliance offline alert for this under Network-wide Alerts
3 REPLIES 3
jdsilva
Thanks a lot!
do you know if that that is possibile too via snmp ?
