MX public ip pool query
Vishal07
Hi All,
Have Mx configure in warmspare where im having public ip pool 1.1.1.0/29. Here i will configure 1.1.1.1 at Router end and 1.1.1.2, 1.1.1.3 and 1.1.1.4 for each MX and virtual ip. Need to know can i use 1.1.1.5 and 1.1.1.6 for vpn configuration and DNat.
Note: 1.1.1.5 and 1.1.1.6 will not configure at any interface of MX.
JamesT91
You can certainly use 1.1.1.5 and 1.1.1.6 for DNAT, but any VPNs (eg. Non-Meraki or Client to the MX) would use the virtual IP.
Hi, yes you can do that. Refer the documentation.
https://documentation.meraki.com/MX/NAT_and_Port_Forwarding/Port_Forwarding_and_NAT_Rules_on_the_MX#...
rhbirkelund
How are you assigning the 1.1.1.0/29 pool? Is it something that you have picked yourself?
1.1.1.1 is a public-ly routed subnet, so I would very much avoid using that on the WAN interfaces of the MX. Considering also that when Meraki Devices go offline and loose their Uplink Connectivity, they tend to be arp'ing a 1.1.1.1 address.
If you do not have a public routed subnet assigned that you can use, try to stick to RFC1918 addresses.
