We have have two MX250's in a high availability config in our primary data rack, and have just upgraded the WAN 1 & 2 links on these to use 10Gbps fibre (previously running 1Gbps RJ45).
The secondary MX had no issues with this, and reports on the dashboard that both links are operating at full duplex 10Gbps.
However, the primary unit has an issue which is causing it to stay at 1Gbps, despite now having 10 gig capable SFP's inserted with the same in the C9300 it is connected to. The catalyst switch at the other end also reports that the links to the primary MX are operating at reduced speed, as it recognises the links should be running at 10 gig opposed to 1.
If anyone can offer some suggestions on how to resolve this that would be awesome. We've already tried a reboot to no avail.
Cheers
