MX in Passthrough
CashG
MX in Passthrough
I have a MX 84 in Passthrough mode. I'm using a FortiGate 60E to do all the routing for the LAN. So it goes Internet  -> FortiGate -> MX 84 -> LAN. I have the MX with static IP on the same subnet as the LAN and going from the WAN Port of the MX to the FortiGate and then I'm plugged into a LAN port of the MX. The internet works, the Meraki dashboard says it has a VPN connection but I can't make any connections to the branch locations. There is nothing complicated at the branch locations, they are connected directly to a MX in routed mode. Is there anything special I need to do with the FortiGate to allow the VPN traffic?
did you add routes on the FortiGate  for the vpn subnets? with next hop the mx ip
CashG
No, there are 10 branch locations. Is there any documentation on what needs to be add? I couldn't seem to find any.
