MX cluster without lan
Hi all
Can meraki cluster works with 2 wan interface and no lan connection?
I'd like to configure the Meraki cluster in a datacenter as AutoVpn Hub and non meraki site to site vpn.
BR
8 REPLIES 8
Re: MX cluster without lan
the lan port(s) of both  mx need to send/receive  vrrp  packets using a layer2 link.
Hi
thanks for the reply, but i need to wan ( one Internet and one Mpls ). In passthrough i can use only one arm configuration, is it right?
BR
Paolo
@PaoloBiagioni What you're trying to do is not a recommended topology. I'd advise you rethink your design to better align with Meraki recommendations.
@jdsilva he was asking about 2 wan port "mode" so i asumed  routed mode
@ww OK yeh that was a fair assumption 🙂
Hi @PaoloBiagioni, what are your goals with the solution? Are you looking to provide SD-WAN type functionality between sites, or are you looking to achieve a VPN back-up to an MPLS link? Depending on what you are trying to achieve there are different designs. And when you talk about internet and MPLS circuits, do you have single circuits, or do you have one circuit of each per MX?
