Hi all
Can meraki cluster works with 2 wan interface and no lan connection?
I'd like to configure the Meraki cluster in a datacenter as AutoVpn Hub and non meraki site to site vpn.
BR
Yup., Just put it in pass thru mode.
https://documentation.meraki.com/MX/Deployment_Guides/VPN_Concentrator_Deployment_Guide
the lan port(s) of both mx need to send/receive vrrp packets using a layer2 link.
Hi
thanks for the reply, but i need to wan ( one Internet and one Mpls ). In passthrough i can use only one arm configuration, is it right?
BR
Paolo
@PaoloBiagioni What you're trying to do is not a recommended topology. I'd advise you rethink your design to better align with Meraki recommendations.
@jdsilva he was asking about 2 wan port "mode" so i asumed routed mode
Hi @PaoloBiagioni, what are your goals with the solution? Are you looking to provide SD-WAN type functionality between sites, or are you looking to achieve a VPN back-up to an MPLS link? Depending on what you are trying to achieve there are different designs. And when you talk about internet and MPLS circuits, do you have single circuits, or do you have one circuit of each per MX?
