MX - VRFs 26.1.2
RaphaelL
MX - VRFs 26.1.2
Hi ,
So VRFs are finaly here on MX. I just deployed MX 26.1.2 on my C8121
What's new
  • Added support for configuring Virtual Router Forwarding domains (VRF) through the Early Access feature program.
So that's true , I can configure the VRFs from the page Organization -> VRFs
But according to my dashboard and documentation : https://documentation.meraki.com/SASE_and_SD-WAN/MX/Design_and_Configure/Configuration_Guides/Networ...
  • VRFs are supported on MX 26.1.3+ in Routed Mode.
  • 7 VRFs can be configured within a dashboard organization to be used in addition to the Default VRF.
So TL;DR , I can configure VRFs but not use VRFs at the moment , am I missing something ?
Is the limit 7 custom VRFs + default = 8  or  6 custom VRFs + default = 7 ? The messages are misleading for a non-native english speaker.
16 Replies 16
Inderdeep
Good, Finally
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
Ryan_Miles
Meraki Employee All-Star
Limit is 8. If you attempt to add more it produce this.
RaphaelL
Were you able to configure a VRFs on a vlan ?
I think I have to wait for 26.1.3 to test it out
MKutka
Still waiting for the Product Team to open this up. Unsure if it's planned for 26.1.3 or it will be an Early Access menu option. Have a inquiry out and will report back.
Ryan_Miles
VRF for WAN is now on the early access page and once enabled it now shows the VRF option on the VLANs page on my MX running 26.1.2.
RaphaelL
Oh great !  I know what I'm working on tomorrow ! 😎
DarrenOC
@RaphaelL , @Ryan_Miles - is 8 a hard limit for just the MX or for a Network?
RaphaelL
8 VRFs appears to be the hard limit for an org at the moment.
Reply to add an 😲 emoji
DarrenOC
Hmmmm, that doesn’t bode well for what I’m looking at
RaphaelL
Did some proper testing this morning and found out 2 things.
1- Firewall logging tools is not VRF aware yet. Not listed in the FAQ
2- Intra-VRF - Inter-vlan trafic is not processed by the L3 Firewall. Not sure if this is expected or not , but I would assume that it is.
RaphaelL
@MKutka  / @Ryan_Miles
Do you know if AutoVPN & VRFs is supposed to be working at this stage ?
Theres a part in the documentation that mentions it , but only my "default" VRFs are currently routed through AutoVPN.
RaphaelL
Somehow I can't upload pictures at the moment.
When I look at the routing table on my HUB :
1- VLAN that works shows 2 entries ( Default VRF ) : Internal BGP + Meraki VPN: VLAN
2- VLAN that doesn't work show 1 entry ( VRF Enabled ) : Meraki VPN: VLAN
MKutka
It is my understanding that VRF's across AutoVPN is supported in this initial release. I've personally have not had the opportunity to test this functionality out. I would recommend opening a support case at this time if something appears off.
lsenecaux
I update my mx85 to 26.1.3 and I created a VRF for guest network isolation purposes.
However, I don't have internet access from this network.
In the routing table, when I select my VRF, I only see my guest network route.
Is there anything I need to do to leak the default route?
Thanks for your help.
Rds,
RaphaelL
same here issue here.
