MX SD-WAN compatibility with other vendors
Flavio_Vieira
How's the compatibility for SD-WAN working with Meraki x Non-Meraki?
We're planning to have a MX at the branch and some other vendor in HQ(maybe Versa's SD-WAN solution).
Do you guys know if the SD-WAN capabilities will work between them?
Does anyone implemented this scenario? I mean MX to any other vendor?
Thanks!
jdsilva
There is no compatibility between the Meraki MX and any vendor for SD-WAN features. I'm not aware of any SD-WAN implementation from any vendor that's compatible with another vendor...
You can nail up an IPsec tunnel between an MX and another device, but you will not get any of the SD-WAN features.
2 Replies 2
jdsilva
Thanks man!
I was suspicious about that too.
