MX Notification on secondary internet link goes down
RichardChen1
Hi Everyone,
I'm new to this community.
My company is building a managed service based on the building meraki dashboard monitoring/alerting features.
After reading the docos, it seems that the alert only supports "The primary uplink status changes".
How do can the system alert me if the secondary/standby link goes down?
Regards
Richard
Alas there is no loss for detecting WAN2 failure.
Your would need to use an script and call an API like:
https://dashboard.meraki.com/api_docs#return-the-uplink-loss-and-latency-for-every-mx-in-the-organiz...
If loss is 100% you can consider it down.
AjitKumar
Hi Richard
I understand this shall not be possible.
However check the following thread.
https://community.meraki.com/t5/Security-SD-WAN/Monitoring-converted-WAN-2-port/m-p/9901#M2442
WANkiller has Suggested a work around. Not sure if you will be interested though.
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
Uberseehandel
@RichardChen1 wrote:
 . . . My company is building a managed service based on the building meraki dashboard monitoring/alerting features.
As this is to be part of a managed services offering, you won't mind diving into the API. Cisco DEVNET hosts the  Meraki Developer Hub, you will find it helpful.
