MX NO-NAT and inbound outbound security rules.
FDM
I have the following requirement an MX-450 on internal network will be used to setup VPN tunnels over MPLS.
There will also be traffic that is going to be routed into the MX-450 interface wihout VPN.
Can i disable hide NAT and create inbound - outbound rules on the MX?
I already searched forum and read it should be possible to disable hide-nat or setup no-nat mode but i can't find where to do this. (running code MX 15.38)
2 Replies 2
DarrenOC
Hi @FDM , you’ll need to raise a ticket with Meraki support to request they disable NAT on your MX.  You’ll then be able to configure what you require
FDM
Hi UCcert,
Thought so, tnx for the feedback.
