MX Inbound Rules
Lorenzo1
MX Inbound Rules
Apologies, if this question is going over old ground regarding inbound rules on an MX, but I'm new to meraki and still wrestling with some of the differences with a traditional L3 FW.
I have a requirement to use a cloud based threat & vulnerability scanning tool to scan branch office networks via non meraki vpn peers (Azure), with the branch infrastructure being MS switches and MR AP's.
Given that 'All Ports' will be need to be open for the scan operation, am I right in thinking that port forwarding isn't the answer, as it's not possible to forward a single TCP or UDP port to multiple LAN devices using port forwarding?
Appreciate any advice.
GreenMan
Meraki Alumni (Retired)
If you're connecting to the MX via VPN (non-Meraki or AutoVPN) then the Security & SD-WAN > Firewall configuration does not come into play (including port forwarding etc).   You do need to get your VPN configuration right though, to enable the desired subnets to communicate:  https://documentation.meraki.com/MX/Site-to-site_VPN/Site-to-Site_VPN_Settings#Non-Meraki_VPN_peers
If the VLANs on the destination MX, that you need to scan, do not have VPN enabled, they will not be reachable.  This is configured under Security & SD-WAN > Addressing & VLANs
In terms of traffic filtering, the ones that affect in-VPN traffic are configured within the Security & SD-WAN > Site-to-site VPN menu.
There is no nat if you connect using vpn.
There are also no inbound firewall rules for vpn
Lorenzo1
Thanks for the reply, looks like I'm out of options for this particular set of conditions.
GreenMan
