MX Firmware / Zero Day / CVE coverage patching and notification ??
Thygesen
Hi fellow MX'ers 😀
I got a question that left me somewhat puzzled ..
Maybe You can enlighten me ?
A lot of "other" firewall vendors boast about quick Zero Day patching and CVE mitigation ..
Question: How do I ensure management that Meraki MX devices are as "up to date" as other vendors ?
Some notification of security updates (like for Firepower) ? New version update notification mail ?
Update method/CVE mitigation procedure for Meraki MX ?
When I go through the MX firmware sections of the dashboard, I can't seem to find any good answers for the above ..
Please assist 😁 Kudos' will rain upon You ..
With Highest Regards
Thyge
8 Replies 8
These are covered off with firmware upgrades.  They are announced here: Firmware Upgrades Feed - The Meraki Community
You will not see the same level of detail that you might be expecting regarding security fixes (except occasionally) so if you need it for a particular bug, you are best off raising a support ticket and should get a quick response.
Thygesen
Hi Cmr 😀 Got that ..
The concern I got was that the update rate of the MX firmware is not impressive, if the CVE resolution is done this way, if You compare to ie Firepower and other firewalls Hot-Fix services..
Seen with management eyes, they see the MX left "un-safe" longer than other firewalls ..
Where do we have docu that shows that MX's are updated as quickly as all the other Cisco firewalls ?
DarrenOC
these devices are built using the largest threat engines - Talos, Snort etc so if something is zero day then I’m often comforted that if Talos has seen it this intelligence is acted upon.
Thygesen
Hi Darren ! ..
These are more directed towards other devices than the MX firewall itself ??
DarrenOC
Hi @Thygesen , on the contrary I would say they’re directed at the MX.  They’re the heart of the MX security.
GreenMan
Meraki Alumni (Retired)
Check the Network-wide > Event log for your MX and filter for 'intrusion' - you'll see the periodic Snort engine updates.   These updates are, incidentally, matched per-link to the List update interval under SD-WAN & traffic shaping:   https://documentation.meraki.com/MX/Firewall_and_Traffic_Shaping/SD-WAN_and_Traffic_Shaping#
Thygesen
So .. Basically we have nothing to show our compliance board in terms of CVE coverage and MX software/Meraki software ?
Rekun
If a critical CVE is found, then firmware is pushed to all devices, as we have seen in the past.
